2021 RDX w/ 2022 Front Bumper
Old 08-08-2022, 12:56 PM
Texass683's Avatar
I have a 2021 SH-AWD with a cracked front bumper that needs to be replaced. I've been comparing the 2021 and 2022 bumpers and the fit looks to be identical. Is this possible and/or has anyone tried this, seen it, done it?
CraigDita (04-23-2024)
Old 08-10-2022, 04:00 PM
eneka's Avatar
i've saw someone on instagram that swapped over. Seems like a direct fit.
Old 08-10-2022, 07:11 PM
swttsx007's Avatar
I’m pretty sure it will work. How much is a new 22’ bumper?
Old 08-10-2022, 08:53 PM
Unobtanium's Avatar
Can you even get one?
Old 04-23-2024, 04:54 PM
4th Gear
CraigDita's Avatar
How have you made out with this….? I am looking to do the same
Old 04-24-2024, 11:05 AM
Texasrdx21's Avatar
Should fit. You may need to get the LED fog lights if yours had them, as they look different on the 22+ bumper.
Old 04-29-2024, 01:03 PM
4th Gear
CraigDita's Avatar
I will be trying this retrofit. As I mentioned, I was involved in a slight fender bender, and I would love to bring my MY ‘20 up to the MY ’22 look, which as you know is a different bumper facia, and I tend to like the cleaner look better. I have ordered a used bumper and will try the fit up myself before bringing it to my body shop for touch up. I will keep the forum posted
Old 04-30-2024, 10:42 AM
Received 1,744 Likes on 1,399 Posts
It should work & be very close.
If you compare & contrast the underlying structural components in the red boxes, on the graphics below for the 20 & 22 RDX, they all look relatively the same between the two model years.
CraigDita (04-30-2024)
Old 04-30-2024, 10:56 AM
4th Gear
CraigDita's Avatar
Yes… in addition, the front corner panels are the same. The only thing that worries me, is the headlights have different part numbers, and also the pentagon grille and chrome surround. The grille and chrome finish can be affordably purchased, but the headlights . Hopefully the are the same shape…. I know they have different shading in them, so hopefully that’s all the differences are….
Let you know soon !!
Old 04-30-2024, 12:14 PM
I'm thinking you don't have much to 'sweat' with your 'swap' project for either the headlights or grilles.
The only difference is the 'suffix' of the headlight part number between the 20 & 22 RDX.
Same thing with the grilles:
Acura / Honda part numbers, from what I understand are:
1) the 'prefix' indicates what the part is, like a headlight. It may change slightly for left & right side.
2) the 'root' indicates what kind of car it fits.
3) the 'suffix' tells detail about the part itself.
Decoding Honda and Acura part numbers - Ultra Racing USA, LLC - Chassis Tuning Specialist Since 2001 (ultraracing-usa.com)
Old 04-30-2024, 03:37 PM
4th Gear
CraigDita's Avatar
Thanks for the info @zeta …. This makes things promising
Beefy_Doc
3G RDX Problems & Fixes
07-19-2022 04:24 PM
Mike Go
07-26-2020 09:31 PM
peterpansf
12-08-2017 09:47 PM
mzhao84
1G RDX (2007-2012)
03-02-2009 05:18 PM
Animagix
1G RDX (2007-2012)
12-31-2006 10:33 PM
Quick Reply: 2021 RDX w/ 2022 Front Bumper
