Carplay issues
Carplay issues
Numerous threads on the sluggish performance, weird beeps, unresponsive UI (when tracking music, etc). I'm in the 23 Type S, latest iPhone, all updates, wired carplay.
Today I tried an experiment. The issue happens for me more on the second trip of my day. Usually, when I first start the car, I let the infotainment boot up before plugging in the phone. However, I do this for my return home trip as well, only to experience worse performance.
See if flipping off the Bluetooth before driving helps. I did this and had no issues. Like anyone, the first thing I did to the car is pair the BT. However, for wired CarPlay - you DON'T need BT. I was not aware of this just because I haven't tried it and it's my first CarPlay vehicle.
My theory is that when starting the car, the system gets busy firing up CarPlay - while also doing some sync over the BT, as if Carplay doesn't exist.
My hope is some of you try this and we can see if things are better....
Flapjackura (04-23-2024)
Yep, I have posted about this in other threads. To minimize issues with the wired setup in my '21 model I have to wait until everything is up and running, especially onboard nav, before plugging in my phone. The Acura system struggles with bootup multitasking. To which I can relate; especially before I've had my morning coffee.
Professional Sh1tposter
It won't. They slapped a very shitty SoC in there and called it a day. 24 is a night and day different. Boots faster, works smoother.
This afternoon I deleted my iPhone from the Bluetooth connection in the TLX. I also turned off my phone’s Bluetooth setting initially. I have turned it back on the phone, but no reconnection of Bluetooth to the car. Significant improvement in the CarPlay connection. Only drove five stops, so still experimenting, but CarPlay boots and connects much quicker. I did have an issue disconnecting a call initially, but not the second time.
Thanks for the tip. Forward progress it seems. Wonder if the Acura Wireless CarPlay adapter will address the conflict between Bluetooth and CarPlay.
Just ran another trip with perfect connection and boot up. Two items. 1. Still have the same “high frequency chirp” that happens when the first source played is CarPlay. A switch to Sirius and back seems to eliminate that. 2. The steering wheel button that accesses Siri doesn’t seem to boot up as quickly as the rest. Had to use the button on the side of the phone for my first request. Worked three minutes later.
Again, forward progress. Thanks again for the idea AdamHodge.
Same results here. Given the results, the system is struggling to boot with competing connections happening. I feel like they should fix it. Yes, faster hardware (likely '24 models) cures some evils. However, I don't think the hardware is so slow it can't be fixed in the code. The OS just needs to manage the process better.
Another setting to try. In the phone app. Go to settings, upper right. There is a setting "Auto Sync Phone". Turn it off and see how things run. For this test, I'm leaving bluetooth on. The phone will still work on the car side if needed. What you give up is contact syncing. However, my favorites are still there when this is off. Per the manual - this setting causes the address book and call history sync when the car starts up.
Bmosbacker
3G RDX (2019+)
11-29-2019 07:27 AM
cyberbro
10-11-2013 11:52 AM
